For loop feeding the constant value from string
I want the user enter the interval number, let's say he enters 10. Then for i=1; i<10 , i++ , then next time if he enters 5 , loop runs for 5 times
so when I created a for loop in labview the number should be constant. The input value is a string so how do I convert  string to constant?
(4,198 Views)
Accepted by Canucks.canucks
You seem to be speaking in some version of C.  This is LabVIEW -- get used to it.  Users can enter data in any kind of Control -- if the control is a numeric control, the input will be a number.  If the control is a String control, it will be a string.  The Block Diagram has (String) functions to convert strings containing representation of numbers (e.g. "10") into number (such as the number ten).
I regret that the Getting Started with LabVIEW Tutorials have been (temporarily, I hope) moved from their place at the beginning of this Forum.  You really need to learn the basic elementary parts of LabVIEW ...
(4,171 Views)
So I changed it to numeric indicator..still same problem
(4,171 Views)
Sorry yes I meant to write a pseudo code rather than labview code..my apologies
(4,168 Views)
Thank you! I changed it to numeric control..
(4,165 Views)
