For loop/formula node/shift register_Beginner question
I'm a Labview beginner and have a beginner question. I think it's for most of u very easy, so please try to help me soon:)
I have (X,Y) datavalues.. I calculated the arithmetic mean using a formula node and a for loop and got (X',Y') out. Now, I want to take the output X' and Y' and calculate a mean value in reference to X and Y. So, the same calculation in the for loop but i want to take the output values and feed it in again as input values. This should be performed N times and plotted.
I tried to use shift registers, but failed to connect it correctly that i can get what I want. I attached here this part of my vi where I have the problem. I hope that you can help me. thanks in advance.
Message 1 of 14
(6,346 Views)
Hi Sarah,
what's the reason to use formula nodes at all for such simple calculations?
You don't even need FOR loops - see attachment…
Please define the next step(s): which values should be averaged in the 3rd/4th step?
Do you want to average X'' with X', then X''' with X''?
Or do you want to average X'' with X, then X''' with X?
Message 2 of 14
(6,334 Views)
thank you so much for ur reply!!
I want to average:
X with X' to get X''
X with X'' to get X'''
X with X''' to get X''''
.. and so on.
this means, I want to take this output eachtime and feed it in one of the inputs.
Message 3 of 14
(6,329 Views)
Accepted by topic author s.steen
Hi Sarah,
so you need to put the X''-arrays into a shift register, while the original X array stays constant:
Message 4 of 14
(6,324 Views)
thank you again. I tried it similarily before, but it doesn't work correctly, because I want to set N iterations ´for example 3 iterations, to get the average values of the whole input arrays, not only the first 5 values.
for N = 3, I have to get for example:
X''''(0), X''"(1), X''''(2),...X''''(n), where n is the size of the input array
Message 5 of 14
(6,308 Views)
thank you again. I tried it similarily before, but it doesn't work correctly, because I want to set N iterations for example 3 iterations, to get the average values of the whole input arrays, not only the first 5 values.
Message 6 of 14
(6,304 Views)
Hi Sarah,
What is "it" and where doesn't it work? What is the exact problem?
My snippet generates averages for the whole array, so what's your problem?
Did you check the resulting 2D arrays?
Message 7 of 14
(6,299 Views)
Message 8 of 14
(6,290 Views)
The resulting 2D Array is fine. I want to set N iterations for taking the output X'' as an input X' and perform this for the whole array. For N=1, an array of 2529 elements. 2 for loops?
Message 9 of 14
(6,285 Views)
Hi Sarah,
there is a clear difference between my snippet and yours! Do you spot this?
Hint: check the inputs of the FOR loop!
Message 10 of 14
(6,282 Views)
