For loop/formula node/shift register_Beginner question
Hello again,
I enabled indexing.. and put a constant in N. It was like to test what happens. the correct picture is attached.2.jpg
Message 11 of 14
(1,663 Views)
Message 12 of 14
(1,654 Views)
Accepted by topic author s.steen
Hi Sarah,
as the result is now presented in 2D arrays: do you mind to check the 2nd dimension of these arrays?
Ever tried to check other columns or to display more than one column?
Do you know how autoindexing works when 1D arrays are used to create 2D arrays?
(Homer would say "Doh!")
Message 13 of 14
(1,651 Views)
thank you GerdW for ur support. I started using LV from some weeks, and what you do is really.. really helpful. Please excuse my beginner attitude!
Message 14 of 14
(1,645 Views)
