Forcer l'etat du port com
Bonjour,
J'utilise dans mon application un port com ( mode classique 9600b...)
Par contre durant l'exécution de mon application il faut que je puisse forcer la ligne TX à "1" (ou "0" ) pendant un certain temps.
lorsque je ne transmets pas d'information.
Comment est ce que je peux procéder ?
Merci
(2,656 Views)
I answer in english because my french Smiley Sad
Better: just a picture
Use the modem line settings (drop a 'number of Bytes at port' and select the break property from modem line settings)
Greetings from Germany
Henrik
LV since v3.1
(2,633 Views)
Ok merci
I will anwser in Engish, but it will be a litle difficult...
Your solution works  ( it's ok ) Thank you
Now i put a oscilloscope on the COM output,
The time is not exacly the same that i set in the prorgam
If i set 10 ms waiting, the real time mesured is 8ms
It's not a very big problem, but do you think it's comming from my computer
How can i be shure the time that i set in the labview program is the exacly time ?
if my engish is too bad, i can write this post in French....sorry
Thank you for your solution
(2,619 Views)
Ok forget my question
The probleme was my oscilloscope
the time base is not good, i test my application with a oder one
Thank you and sorry
(2,615 Views)
