Format Specifier
I record the data of my experiment using Write to Spreadsheetfile. In past experiments, I made a mistake in the format specifier i.e. I wrote: %3.6f (which means width = 3 and 6 digits of precision which is wrong).
I should have written %6.3f. But when I open the recorded Spreadsheetfile with Notepad (for instance), It seems that Labview recorded the data correctly.
Can I trust these data ? If yes, why ?
When I use Read from Spreadsheetfile using the wrong format specifier given above, it doesn't work which is understandable because I use the wrong format specifier bu why it looks like to work when I use Write.
Thanks.
(3,050 Views)
Yes, the first number is a "minimum Field width", meaning it can grow if needed. It is NOT an absolute upper width limit.
Your numbers are probably OK.
(3,044 Views)
Thanks a lot, I appreciate your help.
(3,037 Views)
