put a password to block diagram
Hello!!
I want to put a password to my block diagram.
How I have to do??
Thank you!!
Larson
(3,367 Views)
Go to "VI properties...security". 😄
(3,360 Views)
Hi Larson,
Press Ctrl-I to show the VI Properties of your VI, then select the "Security" tab.  Once you select "Password-protected", you can enter a password for the VI.
Hope this helps,
-D
(3,357 Views)
i tried to put a password like this but its not working. the vi does not ask me for a password when i open the block diagram or wen i edit it.
(3,302 Views)
hi,
After assigning a password to your VI, save the VI, close the VI and exit LabVIEW.
You will be prompted for the password the next time you re-launch LabVIEW and re-open that VI and try accessing to its BD.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,303 Views)
...and if you don't want to restart LabVIEW, you can go to Tools > Options > Environment (on LabVIEW 8.0) and click the "Clear Password Cache" button.  I think it might be Tools > Options > Miscellaneous on LabVIEW 7.1 and earlier.
-D
(3,296 Views)
thanks alot ian and Darren, its working now 🙂
(3,291 Views)
