how to use DAQcard-1200 in labview7.1 under win2000
DAQcard-1200 can only use version 6.9.3 of DAQ driver. measurement& automation 2.2 can recognizes the card as device 1, but Labview7.1 cant find it.
thanks a lot.
(3,485 Views)
According to the product information page the DAQcard-1200 actually needs 6.9.1 or earlier. I would first recommend uninstalling 6.9.3 and trying 6.9.1.
The procedure would be to remove the card, remove the driver with add/remove programs, install the 6.9.1 driver located here http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1293?opendocument&node=132070_US, then reinstall the card.
If you still have problems, let us know what error you get and how you're trying to call it from Labview.
(3,468 Views)
I think the product pages are in error. The DAQ compatibility chart lists 6.9.3 as the most current...
http://www.ni.com/support/daq/versions_pnp.htm
Also 6.9.3 is shipped with the board itself
Message Edited by Chaos on 04-25-2005 10:57 AM
(3,462 Views)
Thank you for pointing that out I will look into the documentation issue.
How are you attempting to "call" the device from LabVIEW? That is, what VI's are you using? What error message do you get?
(3,452 Views)
I resolved it under the support of NI.
I can also use max3.0
(3,436 Views)
Alright thanks for reporting the resolution.
(3,433 Views)
I get the same problem !  I use DaqCard-1200 and labview7.1 and ni daq6.9.3 but under windows xp.
The situation is NI DAQ 6.9.3 has recognizes DAQCard-1200 as device 1, but I can't find a vi In labview 7.1 to acquire data from daqcard.
Can you tell me which vi can be used and where is it ?
Thanks a lot !
(3,300 Views)
