Format string to string with leading zeros
gregoryj wrote:
Edit1: Kudos to James!
Edit2: Wait a second, he said from a string to a string.
Thanks for the kudos anyways Smiley Wink
@Gregory wrote:
@James.M wrote:
I ran a benchmark on the multiple solutions in this thread and there is a very clear winner. Replacing a subset of 8 zeroes wins by a mile:
And I learned you can run a For Loop "1M" times instead of "1000000", awesome!
Just change the display format to SI Notation!
Cheers
Message 11 of 20
(3,555 Views)
Kudos for going to the effort of creating a benchmark VI for my fairly un-optimised solution (like I said...brain not working on a Friday afternoon). However, I have to question as you don't do anything with the results in your benchmark that maybe the compiler could optimise out the operations since you don't do anything with them, nor do you display them - so the compiler might see it as dead code. Just a thought...
(blog)
Message 12 of 20
(3,531 Views)
Oh, good point and it looks like it had an affect. The concatenate solution slows down a bit, the Search/Replace speeds up, and the Replace Subset solution speeds up a bit but is already so fast its hard to tell by how much.
Cheers
Message 13 of 20
(3,517 Views)
Sam_Sharp's idea is not that bad if we replace the for loop with initialize array.
Message 14 of 20
(3,504 Views)
Yes! That was what I was looking for! I knew there had to be a way to avoid the for loop (I was hoping for something like 'repeat string' - but initialise array with a concatenate strings works too!).
(blog)
Message 15 of 20
(3,482 Views)
Here's one more option that I think is slightly cleaner and simpler, and should be fast too. Use the version on the left if all inputs strings are no longer than 8 characters, otherwise use the version on the right:
Message 16 of 20
(3,466 Views)
Sometimes it is easier to operate on byte arrays (The 48 is decimal U8):
(Still needs some exception handing if the string input can be longer than the total intended length)
Message 17 of 20
(3,438 Views)
Many many thanks to you! I worte this question on Friday by hoping that on weekend it can be answered and on Monday I can look for a solution. But what I see here is awesome 🙂 there is solution even with benchmark! I want to accept all of this as solution but it is not possible to accept all of them 🙂
Thanks again.Smiley Very Happy
Message 18 of 20
(3,358 Views)
In fact, you can select multiple replies As Solution. Smiley Happy
There's a strange phenomenon on this board. Every time a string-related question is asked, there are always many different solutions and different answers given. I think the developers here love a good string parsing challenge!
Cheers
Message 19 of 20
(3,321 Views)
I hate them, because invariably there will be some indecipherable regex solution requiring three paragraphs of explanations.
That's why my solution is basically all blue. I don't like strings. reminds me too much of text based code.... 😄
(Just kidding...or am I?)
Message 20 of 20
(3,307 Views)
