Format to Without Space Between Number and Unit
The following yields "123m V" but I need "123mV".  Is there a format specifier option that will inhibit the space between the number and the unit?
Message 1 of 31
(1,846 Views)
Hi Paul,
"Interesting" behaviour…
(I stopped using units more than 10 years ago.)
Not that I know of.
You could strip the unit before the FormatIntoString function and include the "V" in the format string. Then you would get "123mV"…
Btw. the ISO standard for creating text with "values with physical units" requires a space between value and unit ("123 mV"). See this (item #15)! (I typically use a nbsp in text editors…)
Message 2 of 31
(1,832 Views)
I remember submitting a related bug 10-15 years ago. I would have to dig around to see if I still have the scenario.
To your exact scenario, I just don't use units.
Message 3 of 31
(1,831 Views)
This is what I used in multiple situations and swear by.
Santhosh
Soliton Technologies
Message 4 of 31
(1,800 Views)
This only works well without units on the value. (One of the reasons I never use units!)
The  problem is that the OP uses units on the constant.
Message 5 of 31
(1,758 Views)
If units are used, you can use the following format for an SI formatted value
%_3{V}p
Message 6 of 31
(1,661 Views)
%_3{V}p
That moves the space, but doesn't eliminate it.  Also, it only works if the physical quantity is voltage; doesn't work for other physical quantities.
Message 7 of 31
(1,630 Views)
Accepted by paul_a_cardinale
It feels a bit cheap ... but
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 31
(1,466 Views)
Unit agnoistic with space moved, but not suppressed.
Qestit Systems
Message 9 of 31
(1,455 Views)
Not unit agnostic.  It assumes that the unit is a single character (often it is not).
Message 10 of 31
(1,425 Views)
