Format to Without Space Between Number and Unit
@paul_a_cardinale wrote:
@PhillipDBrooks wrote:
If units are used, you can use the following format for an SI formatted value
%_3{V}p
That moves the space, but doesn't eliminate it.  Also, it only works if the physical quantity is voltage; doesn't work for other physical quantities.
Besides Voltage, the {} also works for Gauss and Tesla
I don't have to use it often, but when I do, I appreciate the built-in Unit Conversion e.g. CGS to SI System
Message 11 of 15
(188 Views)
@Yamaeda wrote:
Unit agnoistic with space moved, but not suppressed.
Not unit agnostic.  It assumes that the unit is a single character (often it is not).
Right! I didn't think about that, you have to cut at space instead.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(165 Views)
It is not exactly what you mean (it does not use the unit of the numerical), but here is a univeral number formatter with units included. I use it to display all my numerical values. It also gives the number and unit separately. The caller then has an indicator for both the value and unit. This allows you to nicely align multiple indicators vertically.
Message 13 of 15
(67 Views)
Attempt 2 🙂
Qestit Systems
Message 14 of 15
(31 Views)
@Yamaeda wrote:
Attempt 2 🙂
never surrender ; )
Message 15 of 15
(18 Views)
