Formatting Bug (?)
LV 2012 SP1.
I have a SGL numeric control, formatted as SI notation, 6 significant digits.
When I enter 1n (nano) it displays 999.99900p. I know 1n can't be represented excatly as SGL number, the closest value is 999.9999717...p
With 6 significant digits this should still show as 1n.
So this looks like a bug to me. Btw, the same happens with 1E (Exa), which displays as 999.99900P (Peta).
Any thoughts? Same in later LV versions?
Message 1 of 8
(5,845 Views)
Hi dan,
yes, I can confirm the same behaviour with LV2014SP1.
With 6 significant digits I get the same result as in your image. with >=8 significant digits the result looks ok "999.9999717p"…
Message 2 of 8
(5,836 Views)
I can also confirm that LV 2015 has not changed the behaviour.
Message 3 of 8
(5,833 Views)
Thanks for the confirmation. I usually set 6 significant digits for SGL numbers since this is about the precision of SGL numbers.
I was surprised to suddenly see 8 digits (too wide for the control since the control size was adapted to 6 digits).
So this IS a bug.
Message 4 of 8
(5,825 Views)
Anybody from NI? Can we get a CAR?
Message 5 of 8
(5,728 Views)
If you want a CAR, I suggest you raise a support ticket with NI and then post the number you get from them here. NI employees don't necessarily always see forum threads and raise CARs from - better to raise it yourself (but post it here for others that might be interested in the resolution).
(blog)
Message 6 of 8
(5,713 Views)
Accepted by topic author dan_u
CAR 561864.
Message 7 of 8
(5,678 Views)
Just for completeness: 1n displays fine in automatic or scientific formatting with 6 significant digits. It shows correctly as 1E-9. The bug only appears in SI formatting.
Message 8 of 8
(5,567 Views)
