myRIO UART
Hey guys,
I have a RS232 interface from the Sensirion AFS1430 sensor. Now I try to communicate with it with the following code:
The problem is, that I don't get any response at all. Bytes at port is always = 0. One Warning I get in the while loop:
VISA:  (Hex 0x3FFF0006) The number of bytes transferred is equal to the requested input count. More data might be available.
I also tried changing "line feed" to "carriage return" still the same result.
Using an oscilloscope, I can see that what I am writing is sent via TX but nothing is happening on the port during the while loop (TX is high all the time).
I am getting a little bit frustrated...
kind regards
Slev1n
(5,586 Views)
Hi Slevin
when you use a TermChar you should NEVER use BytesAtPort!
On LF vs CR: The manual of your device should state which TermChar is to be used…
You request to read zero bytes and you get zero bytes…
After googling a datasheet of the AFS1400 I guess you should read page 9 and try a different baud rate…
(It seems both LF and CR are accepted as TermChar.)
(5,581 Views)
Accepted by topic author Slev1n
More importantly - do you have a line driver/transceiver connected to your myRIO? The UART pins on the myRIO are not at RS-232 levels - they are 3.3V (5V tolerant). If your flowmeter is RS-232 - it's signal levels could be anything up to +/-15V - you're risking damaging the pins on your myRIO - you need to put a line transceiver to convert the RS-232 level signals down to 3.3V.
(blog)
(5,533 Views)
I am not totally sure, but you are right, the signals are not +-15V but still out of the range of the myRIO digital Rx Tx ports. I will add a line transceiver and try it again.
Thanks in advance 🙂
(5,511 Views)
