 niedk
			niedk
			03-20-2014 02:35 PM
Is there a way to have multiple formatting methods for a Write to Spreadhseet command? Like I have an array that I want to have specific columns formatted different ways.Or can you only format the whole spreadhseet file one way?
Konrad
Solved! Go to Solution.
			03-20-2014 02:38 PM
Hi Konrad,
when you talk about the WriteToSpreadsheetFile function: yes, you can only have one format for all elements.
You could create your own conversion routine easily as the CSV file format is just pure text using tabs (or comma or semicolon) as separator between the elements…
03-20-2014 03:22 PM
Ok thanks, is there anyway to format the individual arrays before I input them into the spreadsheet file itself?
Konrad
			03-20-2014 03:26 PM
 Dennis_Knutson
			Dennis_Knutson
			03-20-2014 03:27 PM
03-20-2014 03:39 PM - edited 03-20-2014 03:39 PM
Basically I'm trying to create a spreadsheet for value of V,I and R. I need the values for V and R to be in decimal units and I need the values for I to be in exponential format. Previously I didn't care about formatting each of these sets of data differently. I had previously just been wiring the 4155 download trace driver to a 3 element array then transposing the array. I then would write this to the write to spreadhseet function. I'm not sure what the best way is to go about formatting the individual datasets without completing reworking the code I had written before. I've attach a screen shot of what I was doing before.
			03-20-2014 03:50 PM
 Dennis_Knutson
			Dennis_Knutson
			03-20-2014 03:55 PM
03-21-2014 09:26 AM
Attached is a VI which does exactly what you want. It is implemented in the simplest possible way, writing the data to disk a row at a time. If you have more than a few thousand rows, you will want to do this in a more efficient way. Let me know if you need this modification.
Code is in LabVIEW 2011.
03-24-2014 01:07 PM
No that code works great, thanks! I actually had sort of fixed the problem by formatting the values into a string then formatting them before building them into an array. Probably not the most efficient way of doing things but it worked.
Konrad
