Formatting in Word with ActiveX
I need to generate a formatted document in Word from within LabVIEW.
I've got most of it working, starting from an example NI had on their
web site. I am having trouble getting text formatted (bold, for
example) inside a table.
From what I can see, to format text, you need to specify the Range of
a Selection. Range is specified with Start and Stop, in units of
characters from the beginning of the document. When just doing plain
text, I can use the Count method for the Document to find out where I
am. But once I create a table, the table uses hidden characters to
define itself. Since Count returns all the characters in the document,
there is no way to calculate a Start and End for a position inside the
table.
It
seems like there should be some method for returning the current
insertion position in characters from the beginning of the file, but I
sure can't find it.
Can anyone give me a pointer on how to specify a Start and End for
text that you are entering inside a table (or just in general)?
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
(3,024 Views)
Try recording a macro which does what you want, then implement that macro in
LV.
"David Thomson" wrote in message
news:393E6198.3A2E3AA4@al.noaa.gov...
> table.
> It seems like there should be some method for returning the current
> sure can't find it.
> Thanks,
> Dave Thomson
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,024 Views)
