Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
ViRead (VB6)
ViRead (VB6)
gmisk
Member
06-07-2000
11:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi!
I have a problem using the viRead function inside VB6.It reads the serial
port without any problem but at the buffer i´m not reading the right data.I
used a loop to rotate the data inside the buffer but no luck.
Any idea ?
0
Kudos
Message
1
of 1
(2,880 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
