Formula Node error: left brace required ???
I'm trying to use a formula node to do a simple line calculation. However I'm receiving this error and I'm not sure why.
Formula Node: left brace required
Error on line 1 is marked by a '#' character: "y = 0.0183*x -# 0.2982;"
I've tried replacing the y-intercept with a variable, but the same error results.
Anyone know what to do?
Thanks in advance.
(3,228 Views)
What version of LV are you using? The formula:
y = 0.0183*x-0.2982;
works perfectly fine in V6.0.2...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,228 Views)
Hi Mike,
I'm using version 6.1
-Jason
(3,228 Views)
Hmmmmm;Looks like you have found a problem. Where does it want you to put the parentheses?Mike...
LabVIEW Champion
(3,228 Views)
Well, this function runs fine with my LV 6.1...
Something wrong with your installation?
Gerd
(3,228 Views)
