reading the user input, changing size of a 1D array
the size of 1d array should change reading from numeric control
(2,599 Views)
Changing the size of an array isn't that hard when
using the array functions (Array Subset for instance).
See the attached example.
Perhaps you should explain a little bit more the
background of your problem?
Gerd
(2,599 Views)
