Formula Node is not working
hi,
Im trying one equation in formula node but its showing error.  The  error is attached.
the equation  is   z=(500)/[(2^x)*(y+100)
thank you
Message 1 of 10
(4,427 Views)
Accepted by newmemeber123
Just wondering why you might need a formula node when you can achieve the same using LabVIEW primitives as shown below,
Santhosh
Soliton Technologies
Message 2 of 10
(4,415 Views)
What happens if you replace the "[]" with "()"?
(Still, I agree that there is not need for a formula node to do all this 😄 )
Next time, please attach your VI instead. It is impossible debug troubleshoot pictures.
Message 3 of 10
(4,413 Views)
You cannot use a bracket ([ or ]) in a formula node.  You need to use the parenthesis, which can be nested.
Just to be somewhat controversial, I sometimes prefer to use a formula node when math gets "weird".  It just seems more natural to read to me.  This is only when the math gets more complicated beyond a few nodes and variables are reused.
Message 4 of 10
(4,410 Views)
Yes, you "can", but they have special meaning and are used for array indices, for example. 😄
Except that a few minutes later, we need the same operation where the inputs/outputs are arrays. Graphical code will adapt automatically, while the formula node would need extra work. 😄
Message 5 of 10
(4,399 Views)
I knew I was going to get called out for that shortly after I hit "Post".
Message 6 of 10
(4,396 Views)
The error description includes a hint:
Error on line 1 is marked by a '#' character: "z=(500)/[#(2**x).."
So LabVIEW tells you that there is a problem with the bracket.
Message 7 of 10
(4,367 Views)
One of the reasons I don't use the formula node is that the error messages are so cryptic.
Here, the problem is not with a "missing semicolon" as described and it is never really obvious (at least to me) if the "#" is to the right or left of the problem. 😄
Message 8 of 10
(4,361 Views)
I'm 98% sure, the '#' is always after the character that caused the error 😉
Message 9 of 10
(4,357 Views)
Yes, after successfully correcting many errors we learn from experience that that's true!
The statement "Error on line 1 marked by a '#' character" is just not concise enough.
If I were the compiler, I would probably place the # before the problem, delineating the border between good and bad code , i.e. "OK, I was able to successfully parse up to here, but I stumbled going forward". 😄
Good thing we have a graphical code alternative. 🙂
Message 10 of 10
(4,346 Views)
