Formula node problem
Hi NI community
I'm currently working on a VI where I run mainly calculations. I use the formula noda structure which I have a little experience with. I did insert some quiet easy formulas, but when I run the VI something happens which I don't understand. Here's the Formula Node:
This is the problem:
consider the first iteration and don't spend attention to H1,H3 and H4.
In the first iteration my input values are V201 = 0 and pw = 4. So H2 should be calculated to be = 0 (this also happens when I run the VI in highlight execution).
If H2 = 0 also Q1 should be = 0 (also this happens when I run the VI in hightlight execution).
In the next step occurs the problem when I want to calculate VRw2. It should take VRw1 (which is 0 the first iteration) and add it with 0.25 times Q1. Because Q1=0 this should give VRw2 = 0. Instead of that it calculates somehow that VRw2 = 25. For some reason it sees Q1 as 100 instead of 0. In the next iterations it always adds +25 to VRw2.
Has someone an explanation how this can happen and how I can fix this?
I will add the VI (LV13) as attachment so you can try some things out if you want.
(3,954 Views)
Accepted by topic author RutsT
When in doubt, read the help...Formula Node.  There is a special note in there.
Note  The Formula Node accepts only the period (.) as a decimal separator. The node does not recognize localized decimal separators.
(3,945 Views)
I already thought it would be something small like that, but couldn't find it out. Thank you Crossrulz.
(3,932 Views)
