How do you access the DIO pin of sbRIO
How do you access the DIO pin of the sbRIO.
I have attached the code. According to the code the DIO2 indicator is suppossed to blink, but this is not happenning. Can anyone please look into it and let me know (ASAP) where I went wrong?
P.S Its URGENT!
(2,997 Views)
Accepted by topic author kdm7
Your FPGA code is more complicated than it needs to be.  Something like this will do what you want.
Now your RT code...You are simply blinking that LED fater than you can see it.  As some waits between your setting of the output.  I would also use a shift register to hold the current value and then just invert it.  That way you only have 1 write per loop.
(2,953 Views)
