Formulae node error Integer type required.
I'm using some formulae nodes the input data type is double as is the output data type.  It says on the error list that an integer data type is required I've tried using a conversion VI to convert it to integer which has made no affect.  Does any one know how to solve this problem???
Matt.
(3,756 Views)
Please provide more details such as what functions you are trying to use in the formula node.  Perhaps post your VI or a simplified version showing the problem so we can see.
(3,742 Views)
OK I will take that in mind in future but I have managed to solve the problem.
Matt.
(3,738 Views)
