Frame size of chain controls
I'm looking for a way to reduce the size of the frame (like the red outline) while keeping the same font size :
In the same way I'm also looking to maximize a text (width / height) in a frame of fixed dimensions (with the reduced borders).
Do you have a solution for me, please?
Thank you.
Message 1 of 12
(3,646 Views)
What is a "chain" control?
I don't know if you can do it by going to Advanced >>  customize on the control.
One thought I have if you can't, is to paint the background and border of the control transparent.  Place another image behind it that is sized to the frame and white area that you want.
Message 2 of 12
(3,626 Views)
Thanks for your reply.
The chain control is simply a string control.
I've tried to modify the control but it appears that the frame is "linked" with the font size and I can't reduce the frame as much as I want.
Your second solution is a bit complicated to automate...
Message 3 of 12
(3,615 Views)
Hi bbel,
this is what I get for 36pt Tahoma:
How much less do you need?
(Keep in mind: a fontsize of 36pt doesn't mean it uses 36 pixels for font height in LabVIEW, while the Size:Height is given in pixels…)
I agree with message before: use a classic simple string control, paint it transparent and place a decoration behind to fake the control border…
Message 4 of 12
(3,609 Views)
Controls -> Classic -> String & Path -> Simple String
Message 5 of 12
(3,588 Views)
Thanks for your replies.
Sorry, I have to precise that I have 4 string controls one below the other and these 4 lignes have to fit in a 96 x 128 pixels frame.
The idea is perhaps to use a graphic zoom and I'll check that way.
Message 6 of 12
(3,545 Views)
Accepted by bbel91
Hi bbel,
use a 2DPictureIndicator to draw your text...
Message 7 of 12
(3,543 Views)
Hi bbel,
One more idea:
Create 4 string indicators, using classic simple strings as mentioned before.
Paint them transparent.
Size them as needed (as small as fontsize allows).
Move them using arrow keys to fit your arbitrary frame…
Message 8 of 12
(3,505 Views)
Hi GerdW,
Yes thanks, it could also be a good solution.
But with the   2DPictureIndicator I've reached to do exactly what I wanted...and much more !
Bruno.
Message 9 of 12
(3,500 Views)
Hi Bruno,
can you show your solution?
(For other forum users as a suggestion…)
Message 10 of 12
(3,498 Views)
