Framerate
Hello all,
I have the problem that my framerate is only 15 fps instead of 25fps.
I already tried to change the image type, but it has no effect.
If I don't save the images with imaq write my framerate is ok, but I need to save them.
Which other solutions are possible to make the framerate higher?
System:
PCI-Bus 1411
Philips CCD(25fps)
LabView 7.1, Imaq-Vision
Win NT 4.0
(4,798 Views)
Hello!
I believe that you are making both things (acquisition and save) in serial, we can make these two thing in different threads, but send me an example of your program.
Best regards
(4,788 Views)
thanks for your reply. I send you an example of my program in the attachment.
Best regards
(4,773 Views)
Hello again,
It´s possible that the "save" is taking a lot, try to separate them, but with queues.
Regards
(4,752 Views)
thanks, but I didn't work with queues yet. May you send me a litle example? This would be very friendly.
Best regards
(4,745 Views)
Hello again!
This and other examples you can find in:
Open - Examples - Search - Queues
Regards
(4,735 Views)
Hello again,
I've looked at these examples, but they didn't realy help me. I don't know how to put the queue-function into my program.
Bye
(4,726 Views)
