We have purchased the Sound and Vibration Toolkit and I have some questions.
From the frequency response example I looked at you measure the input then the ouput and the Vi gives you the difference.
I want to measure the audio frequency response a radio.
So all I have is the output I dont have the audio input to use as a reference.
How would I measure frequency response with the frequency rasponse VI with only the output audio signal?
I was also looking at the FFT example to measure the audio signal frequency response.
But from what I can tell so far this only does 1 channel I want to do both channles at the same time.
Is there a way to do FFT on 2 channels at once and have them output on the same graph?
Thanks for any help you can provide.
