Frequency sweep with DAQmx
The following is the setup :
LV7.1 + PCI_6229 + WIN_XP
For controlling the drive rpm of a servo motor, I need to generate a range of frequencies from 60 to 2500 at 10 Hz intervals.
With the DAQmx polymorphic VI,  "CO Pulse Freq" , I can generate  a particular frequency. But if I have to change it on the fly how do I do it ? Like ideally if there was a property node for the polymorphic VI (!) , I could easily do it. But it does not have one such node for frequency and hence the query.
Having started the frequency generation at a default value, I would like to alter it programmatically without having to stop the VI and reload the fresh frequency.
Any suggestions welcome.
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(4,455 Views)
There is a great tutorial that describes changing the pulse specs of a pulse train "on the fly".  The second example shows how you can change the duty cycle, but you can also change the frequency with the same technique.  Here is the tutorial:
Advanced Data Acquisition Series – Pulse Width Modulation in NI LabVIEW Using NI-DAQmx
-Alan A.
(4,449 Views)
Dear Alan,
That was the exact information that I was looking for. The tutorial was good.
It has helped solve my problem. Thanks.
Regards
Raghunathan
Raghunathan
(4,442 Views)
Glad I could help 🙂
-Alan A.
(4,430 Views)
Hi
Can one generate an analog sweep with PWM i.e. generate a sine wave sweep from frequencies of 200Hz - 20 kHz.  My applications are limited to the hearing range of <20lHz. I understand I will probably need a low pass filter.
Goy
(4,421 Views)
Hello SG_ENGINEER,
So that is possible, but it is a completely different approach than that mentioned above.  You would have to use a continuous analog output program and change the output waveform.  Check out the attached example.  I modified a shipping example to do an analog output and increment the frequency of the output waveform.
-Alan A.
(4,404 Views)
Hello AlanArmstead,
I have a question about your exmaple VI.
Why do you take the 'Actual Sample Rate' from the property node as a parameter for the Signal Generator? When and why does is differ from the sample you originally specify as an input for the DAQmx Timing VI?
(2,847 Views)
