Front Panel Bank of Switches and related indicators
I am designing a test system.  I would like a bank of switches on the from panel to turn individual test cases on/off.  I've figured out how to do that.  And I can do individual banks for the indicator (pass/fail) LEDs and the numeric test result field.  But, I'd like to tie them all together.  I'm  guessing I should start by using a cluster rather than an array.  But how to I get the various banks to act as a single group?
As I have it so far, I have a back of switches and a bank of indicators (of switch status) for just playing around.  The indicators do not line up with the switches. I'd like a 1-to-1 correspondence for the operator's ease of use.  When I use "properties" to expand the indicator bank, it won't take the number.  It is internally limited somehow.
DH
(3,473 Views)
Accepted by Dark Hollow
How about an array of clusters? Easy to use and easy to look at, all lined up.
Richard
(3,454 Views)
I'm looking at that angle.  I've got a cluster with two arrays.  But that doesn't feel quite right.
Looks like you created an array of clusters instead of a cluster of arrays.  I'll play with that.  Certainly makes more sense.  I just haven't been able to do it.
DH
(3,451 Views)
I've got an array of clusters now.  Much better, but not there yet.
In the example provided, all of the indicators are labeled "T1".  I have the same issue with my implementation.  Change one label and it changes them all.  I would like to see "T1, T2, T3, ..." but cannot find a way to do that.  Also, I'd like each type in the cluster to be labeled at the head of the row or column on the front panel.  I can do this by brute force (just create a text field and plop it next to the array.  But I figure there has to be a more elegant solution.  One that ties the pieces together.
Any thoughts?
DH
(3,443 Views)
Put another element in that cluster that is a string control or indicator.  You can even color it transparent if you want it to disappear and just look like a label.
Then when you build the cluster, you can put a different text string in each element of the array.
(3,441 Views)
DH,
Why don't you post what you have or mock-up what you want with individual controls and maybe one of us can help better?
Richard
(3,432 Views)
