Front Panel Lock on All Controls Value Change Dynamic Event
I have created a dynamic event to detect if any control on the front panel changes values. This works, but locks the front panel after the first time it fires. Under the right-click menu of the Register for Events call, there is an option selected to "Lock Panel Until Handler Completes". If I uncheck this, the event works as expected.
What is LabVIEW waiting for when the Lock Panel option is selected? I am worried I am filling up some queue of 'unhandled events' by unchecking this option as a workaround.
LV2019 example attached, or screenshoted below.
Thanks!
(1,387 Views)
Accepted by JePe1
Right now, you're registering for events every single loop.  You should only be doing this once at the start, outside the loop.
(1,378 Views)
That did the trick, thanks!
(1,363 Views)
Also, forgot to mention, but if this becomes a subVI (i.e. part of a larger program and might run more than once before LabVIEW closes and cleans up everything in memory) then you will also need a "Unregister For Events" node on the other side of the While loop running after it concludes.
(1,360 Views)
