Front panel elements misaligned on target PC (same window size and display resolution)
FYI, you can mark more than pone post as a solution.  Or, if you feel that there were many contributors, but only one answer, you can dispense a kudos or two.
Bill
CLD
(Mid-Level minion.)
Message 11 of 12
(680 Views)
Thanks for the reminder Bill. I had forgotten about Kudos and was unaware that more than one solution could be marked.
Bandit
Message 12 of 12
(670 Views)
