Front panel objects missing
I have a weird phenomena. I have a program that runs fine, does data acquisition and writes to measurement fine. All of a sudden, and in no scheduled way, all the front panel text disappears, which causes the write to measurement to fault because there is no text left to build the filepath. But the funny thing is, after pressing stop on the Labview error, the machine keeps running. There is a digital watchdog in the program that is supposed to stop the machine if the program stops. Anyone had this problem, with the front panel objects/text disappearing?
(4,099 Views)
could you post the vi please?
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(4,092 Views)
VI is too large to attach
(4,082 Views)
ah, can you grab a screenshot then post it as a png file?
(4,079 Views)
Actually I can't, that PC is froze up now and ALL the text is missing, and I get an error message saying "not enough system resources" I'm starting to think the video card or virtual memory is corrupt
(4,074 Views)
ah ok,
hope you get it sorted out
(4,072 Views)
Hi tavwtby,
It sounds like you are running out of virtual memory. Here is a help article on how to extend the size of VM on your system (http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/enable_lrg_ad_aware/). Try this out and see if you still get the same behavior.
Aldo A
(4,051 Views)
