Sub vi missing for applications done in labview 7.1 version.What needs to done?
Message 1 of 8
(4,028 Views)
You do realize that you have a whole message body for adding details. There isn't much to go on with what you have in the subject. You could provide the name of the missing Vi for example. Are you converting to a newer version of LabVIEW or do you get a message about a missing VI somewhere else?
Never mind
duplicate post
Message Edited by Dennis Knutson on 01-10-2007 06:36 PM
Message 2 of 8
(4,027 Views)
Dennis,
I am encountering a lot of problems with running the VI's ...Sub VIs missing like A1 sample channel. vi and AI sample channels.vi , Read from 1100.vi. I am very new to this..apprieciate any help on this
Message 3 of 8
(4,007 Views)
Well, AI Sample Channel and AI Sample Channels aer part of traditional daq. You can install that from your LabVIEW drivers CD or download it from http://digital.ni.com/softlib.nsf/websearch/3DBF3D343476A28F8625709E006A4937?opendocument&node=132060_US .
The VI you posted has other VIs that are missing and they appear to be custom VIs that are not part of a normal LabVIEW distribution. Where did you get this VI from?
Message 4 of 8
(3,997 Views)
Well we got this project from Customer's previous vendor....we have to start the project using the existing VIs ASAP!
I found most of the missing... .except the AI sample channel .vi.  I do still have a long list to check...
Message 5 of 8
(3,992 Views)
The link doesn't work.
Donners
Message 6 of 8
(3,201 Views)
Simply download the traditional DAQ driver by clicking on the Support link at the top of the page and then Drivers and Updates. or from your driver dvd as I mentioned. Note that the traditional driver is not supported on Vista or Win7
Message 7 of 8
(3,197 Views)
failing that type traditional daq into.search box at top of home page
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 8 of 8
(3,193 Views)
