Function and Control Pallet Icons/Glyphs
Is there a way to get all of the glyphs used in all of the default functions and controls? For instance, if I wanted to use the for loop glyph would it be possible to find where that image is stored? I know where all of the built in glyphs are stored, but most of the glyphs basic NI functions and controls use are not in that same folder.
Message 1 of 13
(5,483 Views)
So, you don't know where the build in glyphs are stored Smiley Wink...
Do you want a VI to get the image, or do you want to know where they are stored?
Message 2 of 13
(5,436 Views)
I suppose you are right, I don't actually know Smiley LOL
If you have an answer to both then I will take both! If there were to be only one solution I would prefer it to be the folder location.
Message 3 of 13
(5,426 Views)
Accepted by RyanLC
They are not stored in a folder. The images are packed in a (proprietary) format. This resource file (in the resource folder) contains the .png images. This is undocumented. Getting images from it isn't that hard. I'm not sure if the package contains a name of each resource though. This might be hard coded at compile time (of LabVIEW.exe)...
The attached VI returns a Pixmap of a palette item. It's PW protected, because it contains an undocumented scripting node... That means, run at your own risk. And also that it might change in future versions... If it doesn't work or crashes, you're on your own...
EDIT: BTW, LV18...
Message 4 of 13
(5,422 Views)
I ran into this same issue, some functions (like Add, Subtract, Sign) don't return the correct palette images when calling the private method App : Palette : Get Palette Item Icon. Some primitives are stored as Windows Metadata File (*.wmf) vector images that aren't converted correctly. I wrote a post on how to export all built in function palette icons at:
Export Built In Functions:
https://forums.ni.com/t5/Example-Code/Export-Built-In-Function-Palette-Icon-Images/ta-p/4102957
However, to make things simple, I also exported all built in functions palette items to 256 (8-bit) color png images including both the Item Path (used by Read Palette.vi) and the item display name (used by the private method App : Palette : Get Palette Item Icon).
Built In Function Icons:
https://forums.ni.com/t5/Example-Code/Built-In-Function-Palette-Icons-from-Item-Path/ta-p/4103084
Message 5 of 13
(4,915 Views)
The previous answers are correct about palette items but if you want to know where the glyph are stored that are available in the icon editor.  For Windows, they are in:
[Your Document Folder]\LabVIEW Data\Glyphs
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
Message 6 of 13
(4,882 Views)
Not all palette icons are available in the icon editor glyphs library. You can however get the palette images directly using the App : Palette : Get Palette Menu Items invoke node which returns the image (U8 array) as a Windows Metadata File (*.wmf) vector image.
Message 7 of 13
(4,855 Views)
I have no such method... And I think I have them all.
Message 8 of 13
(4,849 Views)
Here's my solution, feel free to add it to your toolbox 😉
Message 9 of 13
(4,840 Views)
Why not use a .NET wmf object form stream and then convert to the pixmap? The file seems redundant and undesirable.
Palette image.png.Also attached as LV16 VI.
Message 10 of 13
(4,836 Views)
