Function generator errors - Floating point number problem?
I'm using Labview 2012 to control an Agilent 33521A function generator.  For my application, I need to burst the wave with a burst period of 1us.  The issue is setting the wave programatically; if I manually set up a 1us burst period, everything works fine, however if I wire a 1E -6 constant to the relevant input terminal, the VI throws an error suggesting my burst period is too small.  Wiring 2E -6 also works fine, and if I save the manually created waveform to a state and load it programatically, once again, the VI works fine.
The only conclusion I can come to is that there is some sort of floating point error that results in the device receiving a number just shy of 1us.  I tried using 1.1E -6 but that didn't work either.  On the offchance that someone reading this has the relevant equipment to test the VI out, I'm attaching it, along with a screenshot of the VI throwing an error.
If anyone has any suggestions for a workaround, it would be appreciated!
(3,240 Views)
Something to try that might provide some insight would to setup the parameter for a 1us burst and then read the value back programatically and see how the instrument formats the value.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,205 Views)
It says "Burst period extended", so what's the form of the burst? Are you sending X number of waves of a certain frequency that takes longer than 1 us?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,191 Views)
