store numeric value on button click for further calculation
Hi
I have an FPGA loop that is outputing its total running time as a continually updating usec number. On the click of a button I wish to store the current numeric value, and subtract all future values from this number going forward, effectively starting the count over again at 0.
How can this be achieved please? I have been playing around with shift registers and case structure but can not get anything that works properly!
Many thanks!
(3,255 Views)
What you need is to spend some time going through the LV tutorials. Alternately, show us what you have come up with so far. Also, where is this code going to be running?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,217 Views)
In the button click event, read the values and store it in a shift register.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,196 Views)
I don't think, Event structure will be available to use in FPGA VI.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,192 Views)
That is correct, but it is unclear from the OP where this code is to be running - which is why I asked. One possible structure is that the FPGA is simply returning a value and this "reset" logic is running on the PC.
Mike...
LabVIEW Champion
(3,187 Views)
Hi boileroo,
You can use this logic, if you want to implement the code for FPGA target.
You may need to replace the timing functions to what is available for FPGA target.
Timer
(3,181 Views)
