Functional Global not functioning - RT
Following advise from another question I have painstakingly developed a series of Functional Global variable VI's to manage various data in a test rig.  One of them isn't working - GFTR Digital Outputs.vi (attached).
I though I could be clever and use a two-stage Enum-case structure.  The first case is Read-Write to control the action of the FGV. Inside the Write case is another case which detemines which boolena bit in the array to change.
I am pretty certain that the calling VIs are doing their jobs properly.  Indeed I recently added the extra feedback out of the FGV to show the values that are being used.  However the data is not being stored correctly in the FGV.  All elements in the array stay false.
Any ideas?  Do I have to explicitly define each case for the element name?  Or is this a "feature" of RT?
I am using LabView RT 8.6 on a PXI-8106
Ian
(3,766 Views)
Question:
Are you initializing the array in the shift register? You can't replace an element that does not exist.
Ben
(3,759 Views)
Ben,
Of course - the array is uninitialised.  I knew it would be something simple - like meSmiley Very Happy
But the point of an FGV is that the shift registers are uninitilaised isn't it?
If I do initialise the array, will the FGV then maintain the new values, or will it re-initialise each call?
Ian
(3,748 Views)
Accepted by IanDeaville(ZF)
Add an explicit "Init" action and in it create an array and pass it to the SR (shift register). The array should then be available to be acted on with the other actions.
Ben
(3,742 Views)
Consider it done.  Thanks again.
Ian
(3,739 Views)
