Functional global with too many terminals
For i'm stuck might not handle two beers, send one my way! 😄
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 26
(853 Views)
@for(imstuck) wrote:
@Mark_Yedinak wrote:
Oh look at you Greg. Quite the name dropper.
 Smiley Very Happy
(Just giving you a hard time)
Debated long and hard about the name drops, actually. But, I decided they help to improve credibility.
Oh, the wise LabVIEW Champion Mark Yedinak once called me a name dropper, and then I made him buy me a beer at NI week.
The word of a Trusted Enthusiast isn't good enough?
Message 22 of 26
(843 Views)
Apparently not.  Not enough logos in his signature.Smiley Wink
Message 23 of 26
(837 Views)
A bit off-topic;
To reveal a knowldge I have not found anywhere in LabView help.
If you have a subVI that takes big chunks of data as input and proceeds with some algorithm, if it is possible allways inline that subVI.
I had this simple algorithm, that was cutting out some array subset. Algorithm itself took 0ms, the subVI itself took 500ms. After inlining, the subVI itself took 0ms.
Message 24 of 26
(813 Views)
You should NOT inline a funtional global because you lose all statefullness by inlining.....
Unless you've got a constant referring to a Queue or DVR in there the FGV won't work when attempting to share data between processes.
Message 25 of 26
(761 Views)
I was writing about subVI, not FGV. Yes the subVI is in FGV 🙂
Message 26 of 26
(748 Views)
