Functional "Close all Open VIs when Main VI closes" Example
@mcduff wrote:
I would recommend using the Panel Close? event instead. The Application Close? Event should fire in an EXE, but not in the development environment (IDE).
mcduff
You need both, one is for 'X' the other for Ctrl+Q.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 16
(935 Views)
/Y
I never used the other, only the Panel Close Event. Doesn't Crtl+Q initiate a Panel Close event which will then fire?
mcduff
Message 12 of 16
(931 Views)
I just tested it and the Panel Close Event does capture the Ctrl close.
Message 13 of 16
(927 Views)
I have a strong memory there's some instance that sends the Application Close-command, like windows shutting down. It was a long time since i messed with it, i've just done both since then, maybe i never really needed to. 🙂
/Y
Qestit Systems
Message 14 of 16
(917 Views)
/Y
I dabbled a bit in .NET programming a long time ago, and I seem to remember this also, but my memory is way fuzzier than yours.  Believe it or not, I think you had to handle both events explicitly in that dev environment, too - if you wanted to shut down gracefully.
Bill
CLD
(Mid-Level minion.)
Message 15 of 16
(907 Views)
Hoo-hah -- am I remembering Fabiola's VI correctly?  Could she have said "Panel Close?" instead of "Application Close?".  Do I even remember which one(s) I've used?  [I looked at some code several years old, and I was using "Application Close?", and thinking about it, this makes more sense if you are asking how to shut down an entire application ...].
If you are dealing with a Top-Level VI, I'm guessing "Panel Close" and "Application Close" accomplish the same thing.  On the other hand, if it's a Modal VI, they are different.  It might be an interesting thing to see if these two Events behave differently in such a case, one stopping just the VI, the other shutting down the entire Application (just because it "makes logical sense" doesn't mean it actually works that way ...).
Bob Schor
Message 16 of 16
(891 Views)
