Fuzzy controller
1. Actually i have a doubt whether fuzzy controller can be done as simulation part as like GENERAL PID SIMULATOR ,from examples.
or it runs only through real time application.
2.Whatever mode it acts,whether simulation or  real time.how should i enter that rule base.if u have any example,please send me.i cant understand truck procedure in PID control toolkit manual,so please guide me to enter the rule base into that fuzzy set editor and how to load it to the block diagram.
(3,127 Views)
Hi Rahini,
You can certainly use a fuzzy controller in a simulation. There are the fuzzy logic examples found in the same example folder as the PID examples. (Look in Toolkits and Modules » PID Control » Fuzzy Logic  of the NI Example Finder).
If you would like some more information about how to set up the rules take a look at Chapter 7 of the PID toolkit manual. To access the set editor from LabVIEW, click on Tools » Control Design and Simulation » Fuzzy Logic Controller Design. A pop up window will appea and then click on File and double click on New to create a new set of rules for the controller. Follow the instructions in the manual to set up your rules.
(3,053 Views)
