GPIB-USB-HS Error 6 problem with HP 4145A
Hello everyone,
My system: Windows xp, Labview 8.6 and HP 4145A analayzer (SPA) connected to the computer via GPIB-USB-HS interface.
When I try to communicate with the 4145A using Labview I keep getting error code 6, source: HP 4145 send message.
I tried lowering the GPIB communication speed in MAX, but still no success.
Please help,
Kobi
Message 1 of 14
(4,310 Views)
Attach your code so someone can see what you are doing.
Message 2 of 14
(4,296 Views)
I attached the LLB I'm using.
What I try to do, is to take some measures on my 4145A, and transfer the data using Graphics plot.vi at the attached LLB.
Then I get the Error code 6.
thanks,
Kobi
Message 3 of 14
(4,279 Views)
I am attaching 2 SPY captures, taken while I was working on the 4145A.
I used MAX for scanning for instruments (none found).
And I used Graphicsplot.vi (from the previous LLB) for trying to retrieve the measurment data from 4145A.
Message 4 of 14
(4,277 Views)
You should have mentioned that no instruments were found. It does no good to try to run any code until MAX can detect the instrument. Check your cables, addresses, instrument setup.
Message 5 of 14
(4,268 Views)
Thanks for the response.
I can't find the Instrument in MAX, but the 4145A is very old, and I read that MAX can't find some of the old instruments.
I double checked my configuration and setup, and set everything as the manual ordered.
still no success...
Message 6 of 14
(4,252 Views)
Where did you read this? MAX should be able to detect any functioning instrument. Have you tried with a different instrument just to verify the cable and controller?
Message 7 of 14
(4,241 Views)
I have a same problem.
Max can detect 4145a but it can not communicate.
iberr = EABO
I set 1000 sec and I tried different I/O time out but I can not make GPIB_USB_HS communicate.
Did you find solution?
Message 8 of 14
(4,153 Views)
That is not the same error at all since the original poster said the instrument was not found in MAX. What command are you trying to send? Are you using the VISA or GPIB communications in MAX?
Message 9 of 14
(4,150 Views)
The instrument can be seen in the MAX. But when I try to query, its not responding to it and showing iberr = EABO.
Also in the vi file, labview is not communicating with the instrument.
Message 10 of 14
(4,141 Views)
