GPIB vi for HP 3455A ?
I have vi's for the HP 3456A & HP 3457A DVM's that have GPIB
connections. These came in a copy of Labview 4.1 for the Macintosh
Is there enough of a difference between the GPIB operation of the HP
3455A from that of the HP 3456A such that my use the HP 3456A vi will
give me bad data if used with my HP 3455A ??
Thanks in advance.
Dan B
(4,256 Views)
First of all I would go here to get the new drivers and just try them and see.
http://sine.ni.com/apps/we/niid_web_display.drv_results?p_app_area=&p_man=hewlettPackard&p_keywords=&p_inst_type=meter&p_env=&p_drv_type=&p_int=
There is probably not that much different. Sorry cannot help more.
Joe
Joe.
"NOTHING IS EVER EASY"
(4,256 Views)
Dear Dan!
Thank you for choosing National Instruments.
I am guessing that when you say VIs, you are taking about IVI drivers. Now, it may be possible that these are different in operation depending on the instrument and the VIs themselves.
Usually the VIs are compatible with multiple models of the instrument. You can check if this is the case in the documentation of the drivers. However, you can search our driver network to see if there is a specific driver for the HP 3455A that someone has submitted. If that is the case, We would suggest you use those in order to avoid bad data.
Thanks and Regards
ShekharS
(4,256 Views)
