10-25-2004 10:06 AM
10-25-2004 11:21 AM
10-26-2004
01:48 PM
- last edited on
06-03-2024
06:35 PM
by
Content Cleaner
Dear Dan!
Thank you for choosing National Instruments.
I am guessing that when you say VIs, you are taking about IVI drivers. Now, it may be possible that these are different in operation depending on the instrument and the VIs themselves.
Usually the VIs are compatible with multiple models of the instrument. You can check if this is the case in the documentation of the drivers. However, you can search our driver network to see if there is a specific driver for the HP 3455A that someone has submitted. If that is the case, We would suggest you use those in order to avoid bad data.
Thanks and Regards
ShekharS
