GPIB vs COM-port=program stall...
I've made a program which use the com-port to read data from a test object. This serial reader execute continiously. At the same time I use the GPIB to control a switch/control unit.This causes the program to halt.If I then toggle between the front panel and the diagram
the execution continue. Can anybody tell me what cause this problem, can it be due to an IRQ
conflict or something........?
(2,563 Views)
I typically have this kind of application. A temperature-chamber is connected to
COM-port and controlled. In parallel there are GPIB-Instruments under control - like
power supply & multimeters.
But your problem is like finding a black cat in the dark.
Send your program as .llb (zip) to werner.hasche@web.de - I try to do my best.......
Regards
wha
(2,563 Views)
