Unload DAQ Drivers in LabView but keep VI running
I need to share nidaq drivers in both vb programs and LabView programs at the same time. They will not use the hardware at the same time but unlike vb it seems LabView will not release the driver until all VIs are closed. Is there a method to force LabView to unload daq drivers when it does not need to talk to the hardware?
(2,928 Views)
You do not need to quit LabVIEW, but you will need to unload the VIs that
call NIDaq. You can do this by using dynamic loading, VI Server
calls, to load and unload the NIDaq VIs.
Greg McKaskle
(2,928 Views)
In LabVIEW when you would like to use the DAQ functions to use resources on a particular board more than once at a time, you can do that as long as you group the resources when configuring them. So if I wanted to start two Analog Input operations at different times, where the first group of channels started two seconds before the next group of channels, I could use two AI Config VI's with different Groups (and the channels in each group CANNOT overlap) to configure and run this acquisition. That is in labVIEW.
I am not sure about your Visual Basic program, or how it operates, but if you are calling a DAQ configuration function, you might try the group configuration function for the operation that you are trying to perform. For instance, if you are doing a digital I/O op
eartion try calling Digital Group Config VI from the advanced DIO pallet in LabVIEW and the DIG_Grp_Config function in your VIsual Basic program. That way the DLL should recognize that the resources that you are using are not conflicting.
I have not tested this out, and I am not sure that it will help the specific problem that you are encountering, but I thought that I would make the suggestion.
(2,928 Views)
