GPRS web server
May I know how to implement the attached design schema. What are the software and hardware needed.
Does the gprs need a fixed ip address?
Aby suggestion, thanks.
(3,568 Views)
Hi Alex,
GPRS will provide you internet connectivity with the help of SIM card.
For your web server you need an static ip address or DNS name to make available your web page to the internet.
(3,550 Views)
Any where to start with LV web development, thanks.
(3,532 Views)
Hi Alex,
You can build LabVIEW application as an web service and publishing your data on the web page through out the network.
Use Network Shared Variable to stream your large set of data in XML format, create small web page to fetch XML data and display on the web page.
Some links for LabVIEW web services :
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/build_web_service/
https://www.ni.com/en/support/documentation/supplemental/08/labview-web-services-faq.html
http://zone.ni.com/devzone/cda/tut/p/id/7350
(3,515 Views)
