write in 2 columns
write in 2 columns using a "write to spreadsheet file" if I have 2 strings which are in columns
Message 1 of 16
(5,529 Views)
A Little more details please??
Message 2 of 16
(5,521 Views)
I have 2 strings, which are in columns because they have many different numbers, and I would like to write them in the same .txt in two columns, one next to the other using "write to spread sheet file".
I have tried, but they are write in one columns, one after the other.
Message 3 of 16
(5,516 Views)
Look at attached vi
Hope this helps
Dev
Message 4 of 16
(5,512 Views)
This is my VI. The previous answer didn't work ok.
Message 5 of 16
(5,435 Views)
Sorry to say that I have an older version of LabVIEW on my system and hence could not open your vi.
But can you please tell why the proposed solution did not work for you??
Message 6 of 16
(5,433 Views)
This is my VI
Message 7 of 16
(5,430 Views)
Would this vi do??
Message Edited by devchander on 05-28-2007 05:15 AM
Message 8 of 16
(5,424 Views)
Sorry, but it doesn't work either. The problem is that I don't have arrays, I have 2 strings (they were arrays until I change commas by .). Since then, I have 2 arrays, and I want to write each one in two columns, one next to the other.
Message 9 of 16
(5,419 Views)
Message 10 of 16
(5,414 Views)
