GPS Data import into Maps
Hallo  all,
I have GPS data which is ';' separated. I would like to import this data in GPS Maps and I would like to analyse this GPS Data. I would like to know is this really possible in Labview. If it is possible then please let me know.
Thanking You
Regards
Dimpu
(5,430 Views)
Do you want 2D or 3D views of the map?? Maybe you can also use some activex controls. I would suggest a program called globalmapper.
See reply 8 in this thread.
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=3314&view=by_date_ascending&pag...
http://www.globalmapper.com/
(5,388 Views)
You may also want to check out Google Maps.  They have a JavaScript API that you may be able to call from LabVIEW.
http://www.google.com/apis/maps/documentation/
-Josh
(5,368 Views)
