working with parallel port
Hello
I am intersted in working with the parallel port (LPT1 if I understand correctly) - I want to be able to generate an electric stimulus in the LPT port from the vi: what is the way to do it???
should I use the Out Port.vi to do so???
Lava
Message 1 of 8
(3,652 Views)
lava,
You should be able to use the VISA vi's to control the parallel port.
Message 2 of 8
(3,635 Views)
Hello centerbolt
can you please be a little more specific- lets say I want to change the data in one of the pins from '0' to '1', and the addresses of LPT1 in my computer are 0368-037F, can you send me a short block diagram to illustrate your solution???
thanks, Lavi
Message 3 of 8
(3,614 Views)
sorry, the addresses are 0378-037F
Message 4 of 8
(3,612 Views)
Message 5 of 8
(3,613 Views)
lava,
With VISA you just need to use LPT1.  The other part of parallel port communication is that you write to the port, not to individual pins.  This example should get you going.
http://zone.ni.com/devzone/cda/epd/p/id/4213
Message 6 of 8
(3,610 Views)
Is this option ok also??
Message 7 of 8
(3,586 Views)
Out_Port.vi also works.  I personally do everything with VISA.  It makes it easier to write programs that will run on other pc's with different LPT port settings.  With VISA you don't need to know the physcal address the port is set to.  That can be a real headache if your programs have to run on a lot of different pc's.
Message 8 of 8
(3,576 Views)
