GPS and Xbee
Hi bobWalt
Can you please try with this possible solution:
http://digital.ni.com/public.nsf/allkb/E6DFA2B8D7E99F9886256C14005E82F7
This error occurs many times because of the timeout but is not the unique reason
Thank you
Message 11 of 17
(1,710 Views)
yeah still nothing
Message 12 of 17
(1,684 Views)
Message 13 of 17
(1,676 Views)
as the picture show's its still getting power, but nothing
Message 14 of 17
(1,676 Views)
I changed the timeout time and still nothing, for calification
Bobbie!!
Message 15 of 17
(1,675 Views)
I'm having a similar issue.  Is your GPS just blinking in and out it could be not getting a good connection.  That's what my is continuously doing
the pickel!
Message 16 of 17
(1,632 Views)
First, make sure your tx is connected to the rx line of the myrio and rx is connected to tx. Check the Vin voltage and gnd connection. I've never used a myrio and I would first check v communication to a serial port on the pc. I would also use a scope to look at the tx line of the gps unit to see if it is transmitting anything.
Quite frankly, that note from from NI does not address the most common problems with a timeout error. I don't think I've ever fixed it by increasing the wait.
Message 17 of 17
(1,621 Views)
