[GUI] Cannot filter value change event
That's sufficient.....
Norbert
[Edit]: The behavior you are describing is not reproducable in LV 2009f2 with your attached VI. Can someone verify with LV 8.5?
Message Edited by Norbert B on 11-09-2009 07:10 AM
Norbert
Expert: Geometry
Message 11 of 14
(1,354 Views)
Intaris wrote:
The code is OK but the event case should be for the control "Multiplier 1" and not for "Value 1".
The multiplier 1 also has a event case with the same code in it. I guess you did not check the code.
 Slyfer,
Intaris is correct. You have misunderstood the actual discussion. There is no need to have any code inside the value change event case of Value 1 control. You can just delete them.
My last post was understanding that you have a problem for the first time when you RUN the code. I guess the attached vi will solve your problem.
Message Edited by Vsh on 11-09-2009 07:12 AM
Message 12 of 14
(1,353 Views)
No I didn't check the code, my bad.
But the picture showed the event case for the wrong control either way...
Shane.
Message 13 of 14
(1,335 Views)
The key that I missed was to set up the Increment at the beginning of the program.
Then it's done only with multiply value changed event.
Without the initialization at the beginning there is a running bug.
Now it's ok.
thanks
Message 14 of 14
(1,331 Views)
