Gauge HMI - Wrong data representation
Hello all,
I want to use in an HMI the Gauge element from silver palette.
I want to show pressure, this needs to use logarithmic style (The block is DBL).
When the needle point to 1E+1 the digital display shows 1E+3... I don't  understand what is happening.
Any sugestions?
(2,071 Views)
Hi yavs,
@yavs wrote:
Any sugestions?
When you have a problem with your car do you also just show an image of that car to the garage?
Suggestion: attach the VI (or an example VI) to explain the problem with real code we can play with!
(2,058 Views)
