Gauge indicator target mark
Hi All,
Is it possible to add a "target" position to a guage indicator? For example, I am using a gauge indicator to indicate temperature from 0-100C. The process target is some temperature X (variable), I would like to programmably add a small mark or "tick" at the target temperature to indicate that it is the target temperature. See the attached picture for a quick example of what I am trying to do.
Thanks!
Andrew
Message 1 of 8
(4,318 Views)
You could add a second needle to the gauge and then modify the needle's appearance to make it look lime your tick mark.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,280 Views)
you can create your own controls
https://www.youtube.com/watch?v=qvhGH0TlCqs
Message 3 of 8
(4,258 Views)
Thanks for the replies.
I was aware of being able to make my own indicators, but I was trying to see if there was a property node that I was missing.
Message 4 of 8
(4,246 Views)
so, by using 2nd needle?
Message 5 of 8
(4,234 Views)
Yes, that would do it, but by editing the control you could make the other needle distinct from the original one.
Mike...
LabVIEW Champion
Message 6 of 8
(4,214 Views)
two solutions, edit a new control or use second needle...
Best regards
Message 7 of 8
(4,175 Views)
Thanks for all the replies. These solutions will work.
Message 8 of 8
(4,127 Views)
